Will 7mm wires be ok?
Old Nov 7, 2005 | 11:34 PM
Stang9946's Avatar
Stang9946
Default Will 7mm wires be ok?
So I have an MSD ignition in the car now with 8mm wires. I have to replace them cuz a few of the wires are bad. Will 7mm replacements be ok?
Old Nov 8, 2005 | 01:54 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Will 7mm wires be ok?
no...you want the wire with the least resit....I think msd has some 50 ohm ones
Old Nov 8, 2005 | 02:57 PM
Djs94stang's Avatar
Djs94stang
The thickness of the insulation and the wire resistance are not related. To answer the question, you should use at least 8MM wires with a powerful ignition. The diff between the two is the insulation which you need more of with more juice. A 7MM wire will have more tendency to bleed through and potentially crossfire with other wires.
Old Nov 8, 2005 | 07:37 PM
Stang9946's Avatar
Stang9946
I picked up a set of Accel 8mm SuperStock wires. 450 F resistance. 3,000-7,000 ohms per foot resistance.
Old Nov 8, 2005 | 08:48 PM
vfast's Avatar
vfast
I ♥ Acer
not good...my wires has 25 ohms per foot..... so you basically have wasted your money on the msd
Old Nov 8, 2005 | 09:03 PM
Stang9946's Avatar
Stang9946
ORIGINAL: vfast
I didn't waste any money. I didn't even buy the MSD. Personally I think they're garbage.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
