3.8 Coolant Flow
Old Nov 16, 2005 | 08:33 PM
absolutdavis's Avatar
absolutdavis
Default RE: 3.8 Coolant Flow
c
Old Nov 16, 2005 | 11:21 PM
p0rsche23's Avatar
p0rsche23
i dont know if this matters but what kind of gas are u putting in? i know the higher octanes burn hotter and more efficiently but.....no i dont know....i just replaced my water pump cuz it was leaking....i put the higher oc gas in couple weeks before it started doing it so i dont know if that could have caused it?....help me out here
Old Nov 17, 2005 | 03:29 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: absolutdavis
yes, it's been overheating
Only thing I can think of is a clog. Does your heater work? If not then you can trace it back from there. If so..it's gotta be somewhere in teh block where the clog is, perhaps some junk got into the head passages when you replaced the intake gaskets.
Old Nov 17, 2005 | 03:35 PM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: p0rsche23
The higher octane gas doesn't burn hot enough to cause such a problem. The difference isn't that huge. The biggest difference in the octanes of fuel is resistance to detonation.
Higher octane fuel causing your water pump to crack and leak? Very unlikely, just coincidence.
wraith777
Sep 28, 2015 10:49 AM
mrappe
Sep 26, 2015 10:16 AM
col2560
Sep 25, 2015 08:59 PM
MusicCity615
Sep 12, 2015 07:05 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
