351 heads
Old Dec 3, 2005 | 03:47 AM
302pony's Avatar
302pony
Default 351 heads
hi, i am building a 347 stroker motor. my buddy wants to sell me dooe heads out off a 72 351 for 80 bucks. i was woundering if it is worth it to buy them cause i dont have the money for new ones. would i get better performance out of them than some aftermaket heads. also can you guys ballpark how much hp i would be around with 347, performer rpm air-gap, 750 cfm carb and and an agressive cam
thank you, mike
Old Dec 3, 2005 | 01:04 PM
Tim37's Avatar
Tim37
Default RE: 351 heads
if you have a 87 through 95 stock mustang heads just hang on to them for a little while and save your money for a good set of heads if you have a pre 87 motor or a non mutang motor go ahead and buy the 351 heads. but either way save up your money and get a good set of flowing heads for that thing.
Old Dec 3, 2005 | 03:12 PM
nitrous_bob's Avatar
nitrous_bob
for $80 that is a good deal. but your gonna have to spend some money on port work, valve job and hardened valve seats.
those are not from a '72 if they are dooe's those are '69-'70 heads and basically are gt40 iron heads. i'm pretty sure the '72 heads sucked, only the '69-'70 but i could be wrong (i don't think i am though)
when it's all said and done, you'll have a nice set of heads, but will have spent about $600 total
Old Dec 3, 2005 | 06:53 PM
302pony's Avatar
302pony
thanks for the info, the heads a dooe's it is probly is older than what he said he was parting the engine out.
ORIGINAL: nitrous_bob
Old Dec 4, 2005 | 01:57 PM
nitrous_bob
average price for those heads are about $100 so it's no stellar deal.
but just to give you an idea.
Old Dec 4, 2005 | 06:09 PM
tinman's Avatar
tinman
The '72 do really suck.......
I've sold 2 sets of C9's in the past 3-4 years and I get $100 a set for them.
They really don't make a bad head to use if you are 'bucks down'. Do a real careful bowl blending job along with matching the ports.
They seem to really like 1.94 valves too...........
I was using some like this on a 351 in a '67 'stang coupe, smallish hyd cam (comps), 10 compression, 4.10 gear and running 11.95 or so up here in the desert...........
Old Dec 4, 2005 | 09:40 PM
302pony's Avatar
302pony
thank you for your info, im probly going to clean them up and just use them while i save up for aftermarket heads. i dont have the stock heads because i bought a bare block. i also have another question i live in mass so im just woundering will the 347 with an f or x 303 cam pass emisions without any trouble? thanks mike
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
