muffler question possible problem
Old Dec 8, 2005 | 11:26 PM
benz660r's Avatar
benz660r
Default muffler question possible problem
hey i knotice that after i shut my car off in my drive way slight hill that behind the car was a puddle of what seemed to be water with carbon in it? I assume its from the pipe but is this bad that the water was black. The car is used only around town usually running for no longer than 10 minutes...... Is this ok or is there something thats producing to much carbon.
Old Dec 9, 2005 | 12:00 AM
nitrous_bob's Avatar
nitrous_bob
Default RE: muffler question possible problem
thats typical.
nothing to worry about.
Old Dec 9, 2005 | 12:17 AM
83beast's Avatar
83beast
nope, nothin. all cars do it. just, stangs have more carbon than, say, a geo metro!
Old Dec 9, 2005 | 04:18 PM
Chopper's Avatar
Chopper
This kind of driving will age your car prematurely.It will cause sludge build up,fuel injector clogging,and carbon build up in the combustion chambers.It takes about an hour at operating temperature to boil the water and acids that cause sludge out of the oil.To see if sludge is forming,remove the oil fill cap and look inside the cap,if theres a milky looking slime inside it's sludge.The fuel injectors and intake valves will slowly over time,build up varnish and carbon deposits that will cause hard starts and idle problems when the engine is cold.The carbon in the combustion chambers and exhaust can cause pinging and false O2 sensor readings.My advice is to take the car out on the interstate and let it run for a couple of hours a month(at least) to burn off some of these deposits.Blasting up an on ramp is a good way to blow some of the goop out of the exhaust and the combustion chambers and a fun way to spend an afternoon.
drfister
May 3, 2018 10:38 PM
Webster454
Sep 5, 2015 11:06 AM
MustangJourney
Sep 2, 2015 04:32 PM
prophotog
Aug 26, 2015 11:55 AM
vbonina
Aug 6, 2015 02:56 PM
