31 or 28 spline?
Old Dec 16, 2005 | 02:16 PM
95_302_StangMan's Avatar
95_302_StangMan
Default 31 or 28 spline?
How do you know if you have a 28 or a 31 spline rear end?
Old Dec 16, 2005 | 02:21 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: 31 or 28 spline?
31's are an upgrade...if you haven't done it....it's still stock.
Old Dec 16, 2005 | 11:28 PM
Chopper's Avatar
Chopper
31 spline axles were stock on Cobra's.GT's are 28 spline.
Old Dec 19, 2005 | 01:29 AM
95_302_StangMan
ok thx
Old Apr 9, 2008 | 01:01 PM
2abouAziza's Avatar
2abouAziza
If i change my stock spline differential to 31 instead of 28 then i have to change out the axel and make it 31 spline also. Now do any modifications take place or do i just replace the differential with a 31 spline differential, add a ring and pinion, add the seals and bearings of the pinion, add the 31 spline axel and axle seals and bearings? Are the2 bearings and2 sealsof the 28 spline axel the same as 31 spline axel or are their special or different kinds?
thank you
Old Apr 9, 2008 | 04:23 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: Chopper
Incorrect, Cobras didn't get 31 spline until 2001.
All you need for a 31 spline swap is the diff and axles, it's a good idea to replace the seals and bearings while you're taking everything out.
spamedic
Sep 9, 2015 12:15 AM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
gt96stang
Mar 8, 2005 05:07 PM
Fishhawk
Jul 11, 2004 06:51 PM
mikes7950
Oct 24, 2003 03:12 PM
