stroker
Old Dec 17, 2005 | 11:10 PM
302pony's Avatar
302pony
Default stroker
Posted: 12/17/05 9:08pm
hi i was woundering if i bought a stroker crank for my 351 would i need special rods and pistons or can i use the stock ones also what crank do you recomend for a n/a engine and a low cost.
Old Dec 19, 2005 | 12:43 PM
Tim37's Avatar
Tim37
Default RE: stroker
most people go with a 408 it is a modifed 400m crank ya use chevy 454 rods and then you can buy the pistons form pretty much any good piston manfacurer. your block will also have to be preped for all of this.
Old Dec 19, 2005 | 12:48 PM
Lee Willis's Avatar
Lee Willis
Default RE: stroker
I wouldn't think you would want to use the stock parts even if they would fit (they usually won't). You put a stroker in to get a lot more power so its best to go with robust aftermarket parts that can handle it well.
Old Dec 19, 2005 | 05:52 PM
wwmost's Avatar
wwmost
Default RE: stroker
what exactly is a stroker motor? whats the difference in performance and why?
Old Dec 19, 2005 | 09:56 PM
MCFAST's Avatar
MCFAST
Default RE: stroker
ORIGINAL: wwmost
A longer stroke crank, the shorter con rods are so the tops of pistons do not pass the top of the cylnders, they go low in the cylnders, more CCs= more HP and more Torque, longer stoke= much more Torque, and then you can go with a biger bore and get more HP and TQ agan, so you can take a 351w bore it and stoke it to 427, with some good mods you can get over 500HP and 500lps of TQ. I hope this helps.
Old Dec 24, 2005 | 08:19 PM
uedlose's Avatar
uedlose
Default RE: stroker
They have a crank out its a 393 ci crank it use stock 351 rods and a 302 piston that would be the cheapest kit I know of.and with good C/H/I make big H/P. But I would keep the rpms down below 6000. Scat makes this Crank and you can also buy it from Ford,Scat also so make it for them.it will bolt right in to a Windsor block but you may have grind the block some for clearance at the bottom of the bores just like a stroker 302 motor.I am not sure as I have not built a 393 yet.
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
kevin02
39
May 22, 2004 01:39 PM
95_GT_Stang
Apr 10, 2004 04:39 PM
