Tranny cooler
Old Dec 29, 2005 | 11:49 PM
97stanger's Avatar
97stanger
Default Tranny cooler
I am going to buy a transgo shift kit from summit...so i figure i might as well buy a tranny cooler while im at it...i would appreciate it if someone could let me know if this is a good enough tranny cooler to go with?? any input? thanks guys
type " BMM-70264 " at http://store.summitracing.com/
has anyone had any experience with this one and any recommendations??
Old Dec 30, 2005 | 03:33 AM
MAXAir's Avatar
MAXAir
Default RE: Tranny cooler
Hi!
From my experience, the add on oil coolers (tranny coolers) do a good job. The biggest problem is the way they mount. Now, the most convenient way is to supply you a kit that includes little plastic 'ties' that go through the radiator. Those are NOT a good idea. The problems are two fold. First of all, the radiator was not made to take the excess weight. When you install the cooler that close to the rad, there is no room for air to deflect around the cooler. The BEST solution is to have a bracket type mount kit that lets you hang it in front of the rad, leaving clearance.
Hope this helps! Good luck!
jwog666
Dec 27, 2021 08:09 PM
wraith777
Sep 28, 2015 10:49 AM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
