ball joint removal
Old Jan 27, 2006 | 09:21 PM
corvetteguy's Avatar
corvetteguy
Default ball joint removal
My 89 GT lost the left front ball joint. Luckilly
it happend on my road. Got it home and in
my garage (a little dragging) Got the nut
off and bolt and ball off, but the bottom half of
the joint is still pressed in to arm (now empty).
Does it have to be pressed out? or can I use
heat and bang the remainder of the joint out.
Is there another way or do I need to call wrecker to take
to a real garage$?
George
Old Jan 27, 2006 | 09:39 PM
wildcobrar's Avatar
wildcobrar
Default RE: ball joint removal
Put a jack stand under the control arm and you should be able to drive out the remainder of the joint with a large ball peen hammer. I strongly suggest you borrow a ball joint press/installer kit to install the balljoint. This way it will be seated into the control arm properly and without damage to the Bjoint or Carm.
Old Jan 28, 2006 | 09:17 AM
corvetteguy
What does the kit installer look like?
Where do I get it?
Old Feb 2, 2006 | 09:13 AM
corvetteguy
Well had
to call rollback to take car
to shop. ($75) .
The car is back ($59)
All 4 wheels are back on the ground.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
marc954
Sep 29, 2015 11:18 AM
