Non Mustang ignition issue
Old Feb 5, 2006 | 06:46 AM
Magiarn71's Avatar
Magiarn71
Default Non Mustang ignition issue
I really don't want to join another forum, especially a NEON one..... but a friends car has a problem thats turning impossible but probably common to other makes. It wont start. Kicks over for a half second then stops. The starter was checked by a local shop and they "say" that it's ok and doesnt need a rebuild, it works. The battery was changed, no difference. (mind you these werent MY suggestions, they were done before I got ahold of it...) I checked the fusible link box and they looked good, but I swapped them around anyway and no change. I did the same with the relays, no difference. The neutral safety switch was changed; it wants to start but it seems like something is cutting power. No dice. So as a last resort I changed the ignition switch because its cheap and one less variable, STILL WONT START. Now I'm wondering if this shop he had check the starter actually checked it..... Next step is going to town with the multitester, but I need a second set of hands to turn the key.....What else could it be besides bad wiring?
Old Feb 5, 2006 | 03:26 PM
03YellowPony's Avatar
03YellowPony
Default RE: Non Mustang ignition issue
I'd look at the starter AGAIN.
Old Feb 5, 2006 | 03:47 PM
Magiarn71's Avatar
Magiarn71
Thats what I was thinking, they said it was ok and just cleaned it....
djbigskrilla
Sep 20, 2022 01:04 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
