alternator problem
Old Feb 8, 2006 | 11:45 PM
philly3384's Avatar
philly3384
Default alternator problem
When the car first starts up the charge is normal and holds good and the car runs better then as the car runs longer and warms up the cars charge and voltage goes down and, moves up and down when I turn the lights on and off and the heat on and off. Is this the battery or alternator. Its the stock 95 cobra alternator which i think is 130 amps. Also when i turn the wheel the cars rpms drop 200.
Old Feb 9, 2006 | 11:29 AM
Chopper's Avatar
Chopper
Default RE: alternator problem
Sounds like a soon to be dead voltage regulator.Heat causes the wires to expand and the resistance to go up.This is probably what's causing the regulator to vary the voltage improperly.
The engine speed dropping when you turn the wheels could be the IAC is starting to need cleaning.
jma2
Jul 10, 2023 01:00 AM
Golfsito
Oct 6, 2015 11:02 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
