Clutch Pedal Help!!!
Old Feb 15, 2006 | 12:38 PM
Dan9687's Avatar
Dan9687
Default Clutch Pedal Help!!!
I have a 99 V6 Stock Mustang and the clutch pedal has been raddling for around 4-5 months now. The clutch itself I dont feel is bad, though it does catch very high it has never slipped. But I was looking for advice on how to correct this annoying raddling sound in my clutch pedal?
It happens mainly when I switch gears and when Im in gear and apply the brakes(usually 30mph and lower speeds). Thanks for the help.
Old Feb 15, 2006 | 12:45 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Clutch Pedal Help!!!
Need more info. Where is does the noise seem to be coming from?
Old Feb 15, 2006 | 01:36 PM
Djs94stang's Avatar
Djs94stang
I'm not quite sure if your year is included but Ford has TSB's for clutch pedal vibration. Check the Recalls and TSB section. I was looking for something else the other day and I saw the clutch pedal one.
Old Feb 15, 2006 | 02:52 PM
Dan9687's Avatar
Dan9687
The noise comes from my actual clutch pedal itself. It vibrates or raddles. And when I push up on the clutch pedal softly it will stop the noise, obviously because I stopped the vibration.
Old Feb 15, 2006 | 03:35 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: Dan9687
Have you looked under the dash to see what you can see. Not sure if there is a replacable bushing for it or not. Have a look though.
Old Feb 15, 2006 | 06:23 PM
Djs94stang's Avatar
Djs94stang
I know...it is vibrating from the clutch linkage. If it's what I think it is, there is a balance weight that Ford can install on the clutch fork on the tranny to dampen the vibration. Check with engine rpm....you may notice it better.
Old Feb 15, 2006 | 08:42 PM
Dan9687's Avatar
Dan9687
I just went to Ford and they didnt actually look/inspect it but they said it is probably the bushing. And that the bushing is only like $5 but labor to replace it is around $300!!!
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
ccdguy
Sep 19, 2015 05:20 PM
