2001 Mustang
Old Feb 24, 2006 | 02:40 AM
phat2riden's Avatar
phat2riden
Default 2001 Mustang
Can anyone shed some light on how to remove the rear seat in order to get to the passenger side rear panel in order to remove the passenger seatbelt? thanks in advance.
Old Feb 24, 2006 | 04:10 AM
carcrazy's Avatar
carcrazy
Default RE: 2001 Mustang
this might sound sort of like a flame ..but it is not by any means. Have you tryed doing? and couldent figure it out? Or are you just trying to get some tips about doing?
The way i learn is just by doing. I took the entire enterior out of my car and a few hours and i had never done it before.
Old Feb 24, 2006 | 02:38 PM
phat2riden's Avatar
phat2riden
Trust me I have tried to remove it...to no sucess...But I did see the bolts that would loosen the seat ..but if i try to take the bolt out there isnt any room for the actual bolt to be removed from the hole due to NO CLEARANCE...So what i was asking is has anyone ever done this before that could suggest any info or insight..I believe if it does come out(bolt) that would only remove the back half not the bottom half. Hey but thanks anyways...for we all dont know ALL the answer all the time....[IMG][/IMG]
Old Feb 24, 2006 | 04:31 PM
mustang_montana's Avatar
mustang_montana
rear seat has two clips that you have to push in, they are under each cushion. then the frame has to come out which requires removing the speaker tray to get to the bolts. im not sure what holds that whole seatbelt panel in, but it should be easy to get out when you got the seat out of there.
Old Feb 25, 2006 | 03:03 AM
phat2riden's Avatar
phat2riden
Thank You Mustang_Montana.....had u not responded i never would of found those push in clips...at least i got the bottom seat out....Tomorrow i will be able to access the seat belt and try to figure out why it's stuck...Once again thanks a million
Old Feb 25, 2006 | 05:31 AM
1BAD3V's Avatar
1BAD3V
Actually I was wondering how to take the seats out myself and no I havent tried yet. I was gonna remove the rear seats, tire and jack just for alittle weight reduction. With buying my new house, its gonna be awhile until I can mod again. I figured an extra hundred pounds or so could save me a tenth or two.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
01moostanggt
Suspension
Aug 13, 2015 07:48 AM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
