tires on 18's??
tires on 18's??
[sm=feedback.gif]
whats a better set up??
steeda ultralites 18x9.5
255/45/18 front
rear??????
28540/18 or
295/40/18 or
295/35/18?????
which one will look and perform the best>?
what about tire pressure
255/45/18 front
rear??????
28540/18 or
295/40/18 or
295/35/18?????
RE: tires on 18's??
so your saying neither 295/40/18 or
295/35/18 would fit also?/
i dont want them sticking out the fenders either though..
and what about tire pressure i know its not gonna be the same as stock right?
RE: tires on 18's??
He's saying that the 295's aren't going to give you the same 27 height as the stock tires do. An easy way to calculate this is to grab a calculator.
295 / 25.4 = A big *** number, but round it off to about 11.61. That's the conversion for your tire width.
Now take that 11.61 x .40 = 4.644. That's your sidewall. So it's 4.6".
Now take your sidewall, times it by 2... Then add the size of your wheel. 4.644 x 2 + 18 = 27.288 Tire height. I think the stock tires are at 27, so that's not awful bad. You just want your front and back tires to match up, and people tend to get them as close to the stock height as possible so you don't have to alter your speedo. Also, you might want to get the sidewalls to match up a little bit too... That way it's uniform. So the reason why he said the 285 and not the 295 is because they are a better matchup with the 255s.
Hope this helps.
Hope this helps.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
