OCTAIN BOOSTERS?
Old 06-17-2006, 01:27 AM
JayholeUSMC
JayholeUSMC's Avatar
Default OCTAIN BOOSTERS?
Sometiomes i buy the little outlaw octain boosters and add them when i fill up my tank. does the outlaw boosters do anything? one time i bought a NOS Octain Booster with Nitromethane.. i think it boosts it like 6 octain points.
i know how its works... higher octain, bigger explosion... go faster...
just wondering if its a waste of money...
JayholeUSMC is offline
Old 06-17-2006, 01:29 AM
Rt1Rebel
Rt1Rebel's Avatar
Default RE: OCTAIN BOOSTERS?
Yes, you are correct.
It's a waste of money.
Rt1Rebel is offline
Old 06-17-2006, 02:20 AM
chevykiller
I ♥ Acer
chevykiller's Avatar
It is a waste of money. (just in case you needed another opinion)
chevykiller is offline
Old 06-17-2006, 02:23 AM
lugnut
lugnut's Avatar
Well since you asked yes a waste of money IMO. They do not raise the octane as advertised. You are better off buying premium at the pump and just to clarify octane does not make a “bigger explosion†it just slows the burn rate down to lengthen the burn and prevent detonation. aka “PING
lugnut is offline
Old 06-17-2006, 02:45 AM
Rt1Rebel
Rt1Rebel's Avatar
To elaborate on what lugnut posted, increased octane is designed to PREVENT a big explosion. This is important if advanced timing, compression, heat and/or forced induction is a factor, but for a stock tuned engine, it does absolutely nothing for performance.
Rt1Rebel is offline
Old 06-17-2006, 03:40 AM
Tres Wright
Tres Wright's Avatar
As the others said, it is now pretty widely known that octane boosters do not in fact raise the "real" octane value as advertised.
In addition, if you are running a stock tune your car will not run any differently on higher octane fuel. In order to take advantage of higher octane, you need to run a tune with advanced timing. Either that or raise your compression, deck your heads, or put on a power adder
Tres Wright is offline
Old 06-17-2006, 12:10 PM
JayholeUSMC
maybe i should of said the gas burns better then "bigger explosion"...
Old 06-17-2006, 12:19 PM
randy78045
randy78045's Avatar
I have to laugh at these octane threads that seem to come up about once a week lately.... Sooooo.... let me try to explain once more.... octane DOES NOT add power to your engine... anything you do to add octane (including burning premium gas) is a waste of money UNLESS your car needs addl octane to control burn... such as high compression, etc as pointed out above... Can somebody make a sticky for this thread so next week we can just refer people to this thread when the question is asked again...
randy78045 is offline
uberstang1
09-21-2015 09:04 AM
Big Al's 03
09-15-2015 09:05 AM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
FD725
08-11-2015 03:43 AM
Quick Reply: OCTAIN BOOSTERS?
