forging internals cost?
Old 08-17-2006, 10:01 PM
darthvader1111
darthvader1111's Avatar
Default forging internals cost?
so how much will it cost to forge internals to make it safe for 500+ hp at the wheels?
darthvader1111 is offline
Old 08-17-2006, 10:15 PM
jonnyjon84
jonnyjon84's Avatar
Default RE: forging internals cost?
ORIGINAL: darthvader1111
i'd like to know the same thing. and also, what other mods are required when u get up to that high of HP?
jonnyjon84 is offline
Old 08-17-2006, 10:55 PM
Airborneflyguy
Airborneflyguy's Avatar
stock driveshafts are good for about 400 or so at the wheels. You'd need a crank, most use 03/04 cobra cranks I believe. Forged Pistons and rods, valve springs... I'm sure I'm forgetting something but I'd say 4-5grand to do it right...unless you do it yourself.
There's so much you can do as far as porting and polishing and stroker kits, different piston heads for different compression ratios, cams too. The point is if your opening your engine up get it all done at once and done right the first time. Cutting corners and you end up spending more money on install or even , gawd forbid, blowing your engine. It will be expensive and that's the best answer I can give you. Start researching all the stuff I mentioned and you'll get an idea. Just a thought
Airborneflyguy is offline
Old 08-19-2006, 05:23 AM
baha
baha's Avatar
A complete forged rotating assembly costs about 2 grand, stiffening up your valvetrain about 500, head gaskets and canton oil pan for 1k i believe, a block girdle. Just make sure the compression ratio is 8.5:1 or lower.
Check this link:
http://www.seanhylandmotorsport.com
baha is offline
Old 08-19-2006, 02:35 PM
RED121572
RED121572's Avatar
gulp.....and the labor would tack on another couple, three or four grand.
[sm=insomnia.gif]
RED121572 is offline
flash_xx
10-16-2015 07:23 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Drastang
09-30-2015 03:48 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: forging internals cost?
