5.00 gears
RE: 5.00 gears
ORIGINAL: bl1nkage
Do you think 4.10's in an auto would be too much if blown?
Mike
RE: 5.00 gears
ORIGINAL: MikeVistaBlue06
My Saleen SC will break the wheels loose at 20mph with 3.73 gears (and I have an automatic too)..... I wouldn't recommend the 4.10s with the SC. I think the 3.73's give you traction that is just to the point of breaking loose and spinning.
Mike
ORIGINAL: bl1nkage
Mike
what i really need is a graph or chart showing gear size and corresponding 1/4 mile times with the same driver in an otherwise stock gt (and for fun at other hp levels too). that way we could all pick the very best gear depending on hp. i just think no-one has had the ***** to go higher than 4.3, but i really think that there could be a huge advantage there...
edit: the only reason not to go to 5.00 gears would be traction, right? so if i ran slicks, wouldn't 5.00 gears be incredible on the track? i mean it's not like i'm gonna get up over 130mph so i don't need my 5th gear or top end...
RE: 5.00 gears
Mike
ORIGINAL: bl1nkage
Mike
DAMN nice car man. a v6 with 3.73 gears and supercharged by saleen? talk about a GT killer and a great sleeper...wow! what are your 1/4 times?
RE: 5.00 gears
Putting in a gear that size (5.22) with an automatic would be useless. You basically eliminate first gear.
There is no 5.0 gear made for 8.8 because nobody in their right mind would even be considering that ona street car.
RE: 5.00 gears
ORIGINAL: GhostPony
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
