Weird problem with Custom Tune
RE: Weird problem with Custom Tune
ORIGINAL: flewbyu
You run the old gas completly out, fill with the new gas AND THEN drive for 5 to 10 miles to get the new gas circulating BEFORE you switch to the higher oct tune.
I had the same problem with my mustang after my battery died and I got jump started, the one window would not go up, you would have to hold it in the hold time for it to go up. But it worked fine later and still no problems.
ORIGINAL: OxSMSxO
I put in 13 gals of 91, the rest was 87, which is what .8 a gallon? Guess I could have put it in neutral at the gas pump and let it run itself out for an hr [
inyadreems
08-21-2015 09:10 AM
