How to?
ORIGINAL: Mustang Maniac
[align=left]and i have question for you ABS supporters if their so good then why dont any professional road racers like in nascar or the grand am series for example have ABS or better yet off-road racers.[/align]
edit: it is banned by all serious racing organizations (F1, CART, IRL, NASCAR, etc.).
Because its good.......because its good is that all you have to say, if its good then why wouldtheyhave taken it out, by the way did you read thestats i posted even if professionals liked it, those stats alone prove Foreverford and myself are right. And besides in professional auto racing (dirt and pavement) they dont use it knowing it could cause bad accident and in racing its saftey first
ORIGINAL: Black GT
Yes, I read your post. Did you read my entire post? ABS eliminates the driver's skill from the process of braking. One thing that ABS has that allows it to beat even an experienced driver over the course of a race is that it's a machine, it doesn't get tired, it doesn't get scared, it doesn't loose concentration, and often it can brake each wheel with an individual amount of force. It takes the driver's skill out of the equation, out performs other drivers incircumstances as stated above, and is therefore banned by the racing organizations I previously mentioned.
To comment on the stopping stats, I have a hard time believing that the non-ABS test was a complete lockup because of this piece of physics trivia: "The coefficient of static friction is larger than the coefficient of kinetic friction: it takes more force to make surfaces start sliding over each other than it does to keep them sliding once started." --http://en.wikipedia.org/wiki/Coefficient_of_friction Theoretically the road surface shouldn't make a huge difference....it's a different coefficient of friction, but applied to both ABS and non-ABS tests...
No, ABS is not perfect, of course, so assume that it does take longer to stop with ABS in bad road conditions than non-ABS (even though I still don't buy it). As others have stated, what you gain with ABS is the ability to steer while braking, whereas a lockup isn't going to allow it. Personally, I would much rather have the ability to change a lane and stop beside a disabled car than I would crash into it. Making the argument that you'd be able to stop quicker with non-ABS only works if you are far enough away to ACTUALLY stop the car, so for me handling is more important to me than a few less meters of stopping power.
I've barely been able to follow this ridiculous thread.
But turning off ABS on a car designed for it will have terrible results. Your brakes are balanced, they don't have to be thanks to ABS. Without ABS your rear is probably going to lockup before your front brakes and cause a hell lot of fun.
Sounds like hitting a brick wall might be a good idea for some of you guys though
speedyejl what you just said sounds ridiculous, your rear brakes WILL NOT lock-up before your front brakes if you lay on the skids, IF you eas into the skids then yes.
and hypromanGT you miss understood something or youre an idiot. you mentioned Theoretically the road surface shouldn't make a huge difference....it's a different coefficient of friction, but applied to both ABS and non-ABS tests... welli want you to go out on a summer day a lay on the brakes without ABS, then do the same in winter, and i dare you to tell me there isnt a HUGE difference.the following information is from the site you went to find your information.
While it is often stated that the coefficient of friction (COF) is a "material property," it is better categorized as a "system property." Unlike true material properties (conductivity, dielectric constant, yield strength, etc . . . ), the COF for any two materials will depend on system variables like temperature, speed, atmosphere, contact geometry and others.
then for your kinetic and static "THEORY"
The coefficient of static friction μs, characterizes friction when no movement exists between the two surfaces in question, and the kinetic coefficient μk, characterizes friction where motion occurs. While static and kinetic friction differ in value (the coefficient of static friction typically being greater than that of kinetic friction), both result from the electric force acting on microscopic irregularities in two adjacent surfaces.
they result from ELECTRIC force
ORIGINAL: Sonic Boom NH
Trust me you ain’t going to out maneuver what the anti-lock brakes can do for you. Throw your car into a slide and/or lock them up and you are NO longer in control of your vehicle but in it for the ride…
Kind of reminds me of people who drive 4x4 thinking they can drive like there is no snow or ice on the road because they have 4x4 which is of NO advantage once the vehicle is rolling, just weight like anyone else and a 4x4 can NOT stop any better then any other non 4x4 vehicle…
I would leave you anti-lock brakes alone as they give you MORE control then you could ever do on your own…
Yes, for the panicky driver that simply slams on the brakes as hard as possible when the vehicle gets out of shape, there is NO 4WD system that will help them. For an experienced driver in a 4WD as I describe, the fact that the wheels are somewhat locked together does indeed assist in braking as well as accelerating.
In spite of the fact that I am a Texan, I have driven probably over a hundred thousand miles on snow and ice due to living some of my life in Germany and doing extensive business travel all over North America and Western Europe.
To the subject of the ABS, yes, most any driver is MUCH better off with ABS than without it on any road surface.
