Pungent smell
Pungent smell
Driving home yesterday in traffic, I kept smelling a pungent smell. I thought it was coolant, but I checked the coolant level, and it's okay. This morning when I first started the car, I smelled it again. Could it be my catalytic converters? Or something else? It's kind of a sharp, acrid smell. I have almost 5K miles on the car now. The oil was changed at 3K miles to Castrol 5W-20.
RE: Pungent smell
I was about to say that you may have burnt the clutch because you were slipping it too much in traffic, but I see in your sig that it's an Auto, so I don't know what the problem is.
RE: Pungent smell
I failed to mention that I did shower that day, and was wearing deodorant. And I had my shoes on, too. Also, I haven't found any animal remains in the car. Besides, it's not that kind of an odor.
The only thing I can think of is my catalytic converters. Has anyone else noticed an odor from their cats?
RE: Pungent smell
ORIGINAL: offrdmania
Cats smell like rotton eggs if that was the smell
RE: Pungent smell
Check the entire exhaust system for anything that could have dropped onto it either from the bottom of the car, like rubber, or even something like a plastic bag you picked up in your travels. I've seen plastic stick to a header and really stink until it's all burned off. There's no reason the car should just spontaneously start to smell, unless a substance meets a heat source.
RE: Pungent smell
ORIGINAL: Shaman
I was really worried about this because the last time I smelled this kind of smell in a car, it was in my 1995 Crown Vic several years ago. I remember smelling coolant and thinking I needed to check it when I got to work. Before I could get there, though, all of the coolant had gone out of the engine through a hole in one of the hoses. There was no indication of an abnormal temperature on the gauge, BTW. The first indication I had of any trouble was when the engine started acting like it was really hot. I pulled over, and it quit running. Had to have it towed, and paid several thousand for a short block. It has 200K miles on it now, BTW - 70K of it after the overhaul. The engine is an earlier version of the 4.6L modular that's in our cars.
Anyway, thanks for you help.
bradleyb
11-27-2015 07:50 PM
