After-Market Mustang GT LCA's
RE: After-Market Mustang GT LCA's
https://mustangforums.com/m_2493034/tm.htm
In this post you mention the powerhouse shaft is solid with CV's at both ends. I assumed you were talking about their aluminum driveshaft, no?
By the way, I measured the distance from the lca body mount to both holes in my che anti-squat brackets and the way my car sits right now the lower hole is atleast 1/2 inch closer than the stock hole. I was wondering why I had to adjust my lca's so much just to get the pinion yoke nose to go up and now I know.
Thanks for pointing that out! I have no idea what possessed me to make that mistake. I was indeed talking about the powerhouse aluminum shaft. I just wrote CVs instead of universals/cardans.
It has now been edited to correct my screwup!
Ok I have all my new suspension parts on my work bench waiting for a nice spring day to install. I work in a large Steel Mill and have access to bins and bins of bolts and nuts. Could somebody tell me the size and length of the bolts for a LCA install. Would stainless bolts be better?? Probably Metric and would type of nut and washer does it use? Thanks
dly 07 GT/CS
dly 07 GT/CS
Well, here's the problem.
If you belive that you must have new bolts, then you need the bolts from Ford. They are TTY type bolts, these are not an off-the-shelf item.
If you don't belive that you need special bolts then just re-use the stock ones.
NorthAmericanTuning
03-18-2016 11:21 AM
JonnyBlazeGT
08-09-2015 10:19 AM
