WHEEL HOPPPP!!!
RE: WHEEL HOPPPP!!!
Get the adj LCA's and that should help. Even if the car is done at the dealer I would bring it into a custom/hod rod shop that knows pinion angles and how to adj. CrazyAl has manys threads on the rear suspension and pinion angles and how to adj. Do a search under author for last years posts and see what comes up from his posts ....I know it will help. He likes BMR and has the one piece driveshaft as well (I think). Later, hope it helps! J
RE: WHEEL HOPPPP!!!
ORIGINAL: Cyberwolf1986
Well im good friends with the dealership, so i know it isnt the installtion myb the pinion angle is wrong.
RE: WHEEL HOPPPP!!!
Do you have lower control arm relocation brackets on?If the control arm is slanted upward as it approaches the rear wheel, it is actually pushing the wheel up as torque is applied. This can cause bad hop...just a though...
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
