Diablo DS Downloader, problem sending a tune
hey guys, finally got my tune for Ba-ma chips and i downloaded it and hooked up my predator to my computer to send the tune. called doug @ Ba-ma and neither one of us could figure out what the problem was. the speed is set to 115200 and there is a connection. what happens is the DS downloaders starts sending the tune but about halfway through, the lcd screen on my predator says there was a failure with sending the tune. we tried compressing, not compressing, advanced tune, regular; still can't figure out why there's a problem. any help from you Diablo guys would be great. thanks so much in advance. sucks having this new tune and not able to upload it!
RE: Diablo DS Downloader, problem sending a tune
Best of luck, tuner problems suck there are so few options to try and when it gets 1/2 way done and stops must make you just crazy nuts because you know the port and the cable are working so either it's the file or the tuner is not behaving. Try downloading/backing up the tunes that you have on it now and see if you can put them back on again that should tell you if it's the file your working with or the tuner is having a problem.
