VORTECH Install... Now wont start...
RE: VORTECH Install... Now wont start...
Did you take the fuel line off and turn the key forward to see if it's pumping? It sounds like a fuel issue, especially if it did run and now it won't. Obviously your tune worked etc. but maybe your fuse for fuel pump popped. Maybe a bad ground or something else, but it certainly sounds like a fuel pump. Good luck. Let us know what it was.
Checked the fuel pump fuse... didnt pop... thinking it might be a line blown off the Tee in the fuel sender itself.... dont really understand why its not at least tryin to kick over... its just crankin...
yes it's improbable but...check the emergency fuel
cutoff switch (drivers side, located near the hood release).
ORIGINAL: Burton9104
Well car fuel tank is officially getting ripped apart monday buti think a line blew off my "T" connection in the tank... I lifted off the cover and can hear a splashing type noise..... nottt goood... least i found the problem..
09-16-2015 07:53 PM
Soldier GT
08-12-2015 03:46 PM
