REDUCING ENGINE HEAT
Old May 10, 2007 | 08:33 PM
  #21
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: REDUCING ENGINE HEAT
In the past I've used phenolic spacers (I think thats how you spell it) for the intake manifold. Always help the manifold stay nice and cool.
Old May 10, 2007 | 10:03 PM
  #22
RodeoFlyer's Avatar
RodeoFlyer
a larger radiator will only take longer to heat up - it wont truly eliminate the problem. you need to move more air. that being said, the air from the engine compartment needs to get out, to allow more air in.
Prometheus has the best way - heat extracting or cowl hood.
I'd love to know how in the hell (let alone why) someone would wrap the factory manifolds. Have fun with that.
Old May 11, 2007 | 12:04 AM
  #23
HypromanGT's Avatar
HypromanGT
ORIGINAL: RodeoFlyer
Err....what? Bigger radiator == more surface area == faster heat dissipation
Old May 11, 2007 | 01:01 AM
  #24
fordfanboy's Avatar
fordfanboy
I ♥ Acer
LOL
Then I guess under your theory (flyer) - Then a larger oil pan won't help with oil cooling and a larger trans cooler won't help with trans temps??
That was not a informative statement you made. The larger available radiators decrease engine temps around 10º constantly. They don't 'heat up' and lose the 10º...lol
Old May 11, 2007 | 01:16 AM
  #25
owero01's Avatar
owero01
ORIGINAL: suoperdave84
There's stuff called Water Wetter (I think that's the name) You add it to your coolant and it's supposed to cool the engine more efficiently. Never used it though.
Royal Purple makes it.
Old May 11, 2007 | 01:21 AM
  #26
fordfanboy's Avatar
fordfanboy
I ♥ Acer
Good stuff too.
Old May 11, 2007 | 01:25 AM
  #27
Jerseyfury2's Avatar
Jerseyfury2
put in a 165 thermostat for the summer and a bigger radiator
Old May 11, 2007 | 02:04 AM
  #28
RodeoFlyer's Avatar
RodeoFlyer
Yes they do dissipate more heat, meaning it takes longer to heat up. It was not misinforming. I deal with removing heat for a living and am educated in this area. FordFanBoy - a bigger oil pan and a trans cooler are different. Maybe you are one of the 99/100 people who buy hoods with scoops because they look cool and not for what they do. A bigger radiator will only help so much until you can move more air across it. You are only delaying the inevitable. I spend plenty of time at the track to prove it along with the education. I could explain it for you scientificly but I don't have the time andI wonderwhether you have the ability to grasp it.
Old May 11, 2007 | 05:19 AM
  #29
androdz's Avatar
androdz
I ♥ Acer
Ding Ding Ding!!! Round 2
Old May 11, 2007 | 08:42 AM
  #30
CrazyHorse0217's Avatar
CrazyHorse0217
Why doesn't Ford set the fans to run after the engine is turned off? Lot's of other cars do this.
