IS IT IMPOSSIBLE?
#22
ORIGINAL: mx07gt
you forgot to add they were running Drag Radials....or Slicks... cant remember quite right.
ORIGINAL: AmericanMuscle4.6GT
a lot of the effort should be put into dialing in the suspension. MMFF got a stick GT to run 12.51 with a CAI/tune as the only horsepower adding bolt on; the rest was done with suspension/weight savings (FULL INTERIOR) and aluminum D/s.
oh yea............and this was with stock 3.55's
#23
You need:
Racing Seats
Rear Seat Delete
5.2L Stroker
39LB Injectors
Higher Hp Supporting Fuel Pump
Windage Tray
Oil Pan
Higher Flowing Fuel Rails
Remove all sound deadening material
Remove Carpet & replace with Dynomat
Bogart 15" Wheels
Slicks
Carbon Fiber Body Panels
Spoiler Delete
Aluminum Driveshaft
Safety Loop
A/C Delete
Stereo Delete
C&l Racer
103 Octane Race Fuel
udp's
cmdp's
electric water pump
gt500 throttle body
k-member
QA1 Coil-Over Suspension
torque limiters + k-member brace
subframe connectors
lca's
adjustable uca's
longtubes + midpipe
a-arms
P&P'd Heads
Crane Stage 4 Cams (552 intake lift,600 exhaust lift)
Battery Relocation Kit
Spec Clutch
Aluminum Flywheel
4:30 or 4:56 Gears
swaybar removal + lightweight radiator support
VCT Delete(Cause super high lift cams)
Higher Stall Converter
Then maybe. But it would be a super rough idling, unstreetable car. It's not worth it IMO. Just shoot for high 11's. Thats a more realistic goal you couldset while still having a streetable car.
Racing Seats
Rear Seat Delete
5.2L Stroker
39LB Injectors
Windage Tray
Oil Pan
Bogart 15" Wheels
Slicks
Spoiler Delete
Aluminum Driveshaft
Safety Loop
A/C Delete
Stereo Delete
C&l Racer
udp's
cmdp's
electric water pump
gt500 throttle body
k-member
subframe connectors
lca's
adjustable uca's
longtubes + midpipe
a-arms
P&P'd Heads
Spec Clutch
Aluminum Flywheel
4:30 or 4:56 Gears
#24
You could do high 11's with:
C&L Racer
Full Exhaust(LT's,Mid-Pipe,Mufflers)
UDP's
CMDP's
Gt500 Throttle Body
Electric Water Pump
4:10's or 3:73's
P&P'd Heads
Stage 3 or 4 Comp Cams
Spec Clutch
Aluminum Flywheel
BMR rad. support
a-arms
k-member
adjustable shocks
aluminum driveshaft + safety loop
lca's
adjustable uca's
Custom DynoTuning
C&L Racer
UDP's
CMDP's
Gt500 Throttle Body
Electric Water Pump
4:10's or 3:73's
P&P'd Heads
Spec Clutch
Aluminum Flywheel
BMR rad. support
a-arms
k-member
adjustable shocks
lca's
adjustable uca's
Custom DynoTuning
