Saleen pully question.....
RE: Saleen pully question.....
ORIGINAL: hotairgypsy
are you worried your engine is a ticking bomb...The reason i ask is I am planning on going with the saleen setup too and rather just get the best setup before I have go to internal. Are you confident all will hold up with that power to the ground?
I'm not so sure about the stock pump yet. It seems these cars are very different from one another. With my 3.6 pulley, I'm just touching an A/F of 12.0 at 6,000rpm. When I get to JDM next month, if I'm not over 420 rwhp I'll ask for a pulley swap. Just hoping they can keep me from running lean with that. LT's my make your situation worse too.
ORIGINAL: drbobvs
as far as my A/F it stayed at 11.5 all the way through....very flat.....even with the LT... i have read a few who have the 3.4 with stock fuel pump no issue...I keep going back and forth on it though
Hmm, considering ARH w/ catted X, I probably should have em with me when I get to JDM.
I guess it's best to get Justin to do a pulley swap while on the dyno, and you really don't need a new belt.
1) The tensioner should have more then enough travel in it to accomodate the .2" smaller pulley.
2) If not, you can easily, and preferably put back the stock idler pulley in place of the plastic Saleen one or...
3) Replace the stock alternator pulley in place of the Saleen one.
Both of the OEM pulleys are a little larger and will compensate for any slack. I'm stll running the stock Saleen belt with the 3.6" pulley and no slippage issues. The belt that JDM gives you "for the 3.6" is only 1/4" shorter in length.
-Rob
-Rob
mungodrums
09-28-2015 10:54 PM
