NEED lca HELP RIGHT AWAY..PLEASE
i AM installing the Adj lcas right now and I am in the processing of torqueing it all down and I ran into a possible snag,,,The bolt on the rear axle tqs down to the 129 no problem but the front is not tightening down as easy...is the one on the body suppose to be 129 also or less...i do not want to blow it up...I know they are one time use but after reading here several have had sucess reusing the same so i am trying.
what ya all think?
what ya all think?
RE: NEED lca HELP RIGHT AWAY..PLEASE
thank ya sir for da help...All is back together for the moment...i am not looking forward too the UCA ...that looks interesting to do...especially with a tq wrench...
It's not the easiest, that's for sure. I tried dropping my gas tank and couldn't get those damn bolts out for nothing so i just took all the bolts out for the upper control arm mount and that gave me enough room to get a wrench and socket on the upper control arm bolt. I did the same for retorquing the upper control arm bolt. I'd recommend trying that before you try to lower the gas tank. There's no reason to remove the upper control arm mount if you aren't replacing it.
ORIGINAL: hotairgypsy
JonnyBlazeGT
08-09-2015 10:19 AM
