AT to MT tranny swap?
RE: AT to MT tranny swap?
well, a lot of work and a lot of money. on the sn95 it was a couple grand and a day of work, so for these cars, it can't be any easier. My guess is that the tranny will run you anywhere from 500-1500 depending on condition, shipping, and if it's "built". You'd need a lift, tranny jack or several buddies, new driveshaft, either a serious new tune, or a completey new PCM, clutch assembly, new brake master cylinder so that there is a line to run to the clutch, obviously a clutch disk. someone else can fill in the blanks, but I'm guessing 3K-5K depending on how much you're willing to spend.
GFL
Good Freakin Luck.
Trade her in for one with a MT.
Mucho less headaches unless
you really like working on your stang.
Anywhere from the PCM to all the hardware
needed along with the clutch pedal and on
and on.
Good Freakin Luck.
and on.
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
