burning, frying, roasting the tires?
RE: burning, frying, roasting the tires?
ORIGINAL: howarmat
Yeah that is my problem.....it doesnt sit there and spin like it used to......a little rubber laid and then takes off.....good for the track, sucks for trying to put a show on[:@]
ORIGINAL: AmericanMuscle4.6GT
thats where it says cold tire inflation pressure. tires say 44 max, i think optimal is somewhere in between. they'll wear faster and get worse mileage if pressure is too low.
ORIGINAL: MartyMoose
I thought they were only like 32psi?
ORIGINAL: 06VistaBlueGT
You'll get better mileage but your tires will wear faster. If your tires are over inflated, you're putting more pressure on the middle part of the tread. You will eventually notice that the middle part f your tread is gone but there is plenty of tread on the outside of the tire. I too thought that the car ran much better with 40 psi, then I took the tires off for the winter and noticed they were almost bald in the middle.
The pressure that's shown on the plateis what you want to use under normal driving conditions. It maximizes handling, traction, and tire wear.
ORIGINAL: ski
+1
The plate is only good for OEM tires which are typically rated at 35 psi.. Most people forget that.
ORIGINAL: Derf00
40 PSI on a 44 max PSI tire is WAY too much. Both my tires and my wife's state 44 max psi on the sidewall. I keep both cars at 37 cold Psi. that's Plenty. 40psi is like a rock. You will get tire spin and lose traction very easliy at 40 and above. If you rotate your tires like you're supposed to you will get pretty even wear. 32 is too low unless you're at the strip. You will get outer tire tread scrubbing from that when you corner hard.
careful settin em too high.. i wouldnt go over 35.. reason being, ya, you get better gas milage, and correct, it is bad to have them under like 28.. for mileage and wear reasons.. but when they are at 40, you wont get and even tread wear either, they will wear faster then if it was at 32.. bc you wont have 100% tread touching the surface.. it expands outwards, almost eggshaped, and it wont wear evenly, mainly all in the center..
and you also run a higher risk of if you hit a pot hole, or anything in the road, or a curb for sure.. your lookin at higher chances of a blow out or side wall damage, which means you can expect to have to buy a new tire, because there is no safe fix, that any shop will do..
any other quesitons, ask me, i work at discount tire, so i can probly help.. (PM me tho, bc i probably wont check back to this thread)
ORIGINAL: Derf00
Also, theOEM Pirellis on my Stang are rated 51 psi max, I always keep them at 32 psi, rotate them every 5K miles, and they are wearing evenly.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
KingRando
10-02-2015 08:06 AM
