Cooling System Upgrade
#42
RE: Cooling System Upgrade
that's custom made and installed? or did you install that yourself? either way that is cheap, what about the water pump for the SC are you still using the one that came with the KB?
#43
I think Adam sells the complete saleen kit for about $350 and it's an easy install (1/2 hour)
No - I upgraded the water pump a long time ago. I also upgraded the heat exchanger to an afco dual pass. I also use a tensioner pulley in place of the idler pulley on KB's kit.
09-17-2015 07:32 PM
09-10-2015 08:39 PM
