I have a 2007 GT convertable when the dial is pointed to heat it only blows out the defroster. When i brought it to the dealer they said its normal they all do it. My 2005 GT convertable does not do the same, ???? if you have a 07 and it doesen't blow out the defroster when you set it to heat please let me know. I'm trying to collect data to take to the dealer.Thanks Daba
There is a wire harness on the back passenger side of the center console behind the dial....make sure that is completely tight, if not that is where the problem is. Other than that i am not sure
Are you not getting anything at all from the normal vents when it's just set to heat? I get a little from the defroster in most of the settings, but the majorityof the air comes out of the proper holes.
