Supercharger Coolant Question
Old Feb 3, 2008 | 12:47 PM
sevenleaf's Avatar
sevenleaf
Default Supercharger Coolant Question
Just a quick question, After driving my car for 25 - 30 minutes Iopen the top to the supercharger stick my fingerin and thecoolant is still pretty cold. Is this normal? The car coolant is really hot. Thanks
Old Feb 3, 2008 | 01:00 PM
hammeron's Avatar
hammeron
Default RE: Supercharger Coolant Question
normal. it would be hotter if you did some
WOT runs and immediately pulled over and
stuck your finger in there...
it's really onlycompressed air, that will bring
the I.C. h20 temps up above normal operating
temp
Old Feb 3, 2008 | 06:41 PM
moosestang's Avatar
moosestang
Are you sure your pump is working? Does the saleen have a see through reservoir? You should be able to see it moving.
Old Feb 3, 2008 | 07:25 PM
bad1032's Avatar
bad1032
mine is the same way, mine has the new setup where the pump runs all the time, The 80/20 mixture is never above luke warm at the best, No where near like the radiator temp.
Old Feb 3, 2008 | 07:27 PM
sevenleaf's Avatar
sevenleaf
Yes I can seefluidmoving when I pull the top off I can also feel it flowing through the tubes. My pump turns on when I turn the ignition on.
Since my coolant iscold does that mean the heat exchanger is doing its job and I don't need to upgrade it?
After I've been driving and pull the top off the supercharger reservoir it is pressurized too.
Old Feb 3, 2008 | 07:30 PM
CataclysmGT's Avatar
CataclysmGT
Normal driving the compressor is barely doing any work, which means very little heat is produced.
Granatelli Sales
Jan 20, 2020 12:34 AM
Vrooom
Feb 21, 2016 05:25 PM
Gene K
Oct 21, 2015 11:37 PM
MusicCity615
Sep 12, 2015 07:05 AM
