Warning TSB Just an FYI
Old 03-09-2008, 07:18 PM
wentw1tj5773
wentw1tj5773's Avatar
Default Warning TSB Just an FYI
I had to take the car into the dealer to have the oil changed because I just got out of hospital and could not do it myself. When they ran my VIN number they said there is a HIGH Warning TSB out for your car. My car has a build date of 02/18/2006, date sold to me was 03/10/2006. I have a tune and I was able to ask my service tech that works on my car at ford, I only have one that I will let work on it. He said to make sure you detune your car be for bringing it in for service, the car will not run if we do this update and there is a tune in the computer. TSB says “ there is something wrong with the passenger side airbag” this work is going to take place on my car tomorrow.
wentw1tj5773 is offline
Old 03-09-2008, 07:25 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: Warning TSB Just an FYI
that is false, your dealer is wrong.....the recall has been around for awhile now and people have got it done....it doesnt touch the tune at all
howarmat is offline
Old 03-09-2008, 07:30 PM
wentw1tj5773
ok good that makes me feel much better
Old 03-09-2008, 07:31 PM
ajaibr
ajaibr's Avatar
I just got it done on my car on Friday. They don't need to re-flash your computer to do the recall.
ajaibr is offline
Nuke
Nuke's Avatar
Matt is correct. The recall invloves an update to the Restraint Control Module (RCM) and not the PCM where our revered tunes reside.
Nuke is offline
Old 03-09-2008, 07:36 PM
howarmat
s197 Junkie
howarmat's Avatar
https://mustangforums.com/m_4700796/tm.htm
howarmat is offline
Old 03-09-2008, 08:44 PM
GT06GT
GT06GT's Avatar
his dealer is 5% right If you have an 06 like mine, with the computer code TJF1 and you take it in for the recall, then yes they dont need to update your PCM to do the recall work, but while its there, they may notice that there was an update to TJF1 and update your PCM while your there. Easy fix for when u take it in is, tell em u dont want any damn updates to your PCM even if its gonna give you 50 mpg
GT06GT is offline
Old 03-09-2008, 08:53 PM
brad281
brad281's Avatar
About how long did it take for the dealer to update the rcm?
brad281 is offline
Old 03-09-2008, 09:08 PM
Goldenpony
Goldenpony's Avatar
Just had my '06 done, didn't take very long at all. I was there less than an hour
Goldenpony is offline
Old 03-09-2008, 09:59 PM
ajaibr
ajaibr's Avatar
ORIGINAL: brad281
I got the 7am appointment so I was the first one being worked on... My car was back outside and done in less than 30 minutes...
ajaibr is offline
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
04stangman
09-26-2015 09:33 AM
Quick Reply: Warning TSB Just an FYI
