KenneBell Boost a Pump ?
RE: KenneBell Boost a Pump ?
ORIGINAL: hammeron
so modaddict..... is it safe to say that
the BAP setting = max potential fuel
pressure and that regardless of the
BAP setting, the PCM is simply
maintaining a certain fuel rail pressure to
achieve the desired a/f ratio?
ORIGINAL: jadeat
It comes stock with 3:55 gears.
ORIGINAL: D_Gusler
Does thecar have gears installed by chance??
BTW, I average around 19-20mpg all in town.
From what you described, it sounds like your numbers are off in the tune to me. Does your mph seem correct?
ORIGINAL: modaddict
Are you still on the stock tires?
ORIGINAL: jadeat
ORIGINAL: D_Gusler
I could be wrong but I dont think that 275/40/20 is the stock tire size. That tire is 28.8" tall. A stock mustang is 27.2" tall. Unless Saleen puts these tires and reflashes the comp they dont sound right.
It might explain the difference as 1.6" is quite a bit. If you have an X-Cal or something try and reflash your tune with that tire height and see what happens.
ORIGINAL: MustangGT0405
Yeah, they added those tires as stock and I hope they tuned the computer accordingly from Saleen.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
