More "Whipple" problems......*sigh*
#61
RE: More "Whipple" problems......*sigh*
ORIGINAL: CataclysmGT
After Justin looked at the part throttle datalogs from idle to 6000 RPM, he has a feeling my car is just different. At idle, the fuel trims were showing a 22% correction, but above that it was only a 5% correction. I think this means no vacuum leak.
He has given me a new tune with 2* timing pulled, and +3% fuel increase at WOT. Until I get a few runs with a/f, he can't do any more. I'm getting dyno tuned next tuesday anyhow, so I will pass the datalogs etc on to him so he can confirm his theory.
#62
I've done as much as I can with what I have been given so far. A wideband provides extremely valuable data when tuning a supercharged car. Reviewing datalogs with wideband air/fuel ratio is included in the price when someone buys a blower tune from me, I highly recomend taking advantage of this part of the service. The FRPP is a one size fits all tune that is much more conservative and designed for 91 octane, it works on your average mustang, at the cost of less power.
The Gen 2 blower is not an issue.
Driving your car around easy is not going to hurt anything. Contrary to popular irrational beliefs, you can't hurt an engine by running lean if there is no load on it.
In a pinch, you can install a wideband in the rear O2 bung and get pretty decent readings.
Several people brought up using the Ford Racing tune with a relocated IAT sensor. This is not a problem. The FRPP tune pulls very little timing based on air temp, actually less then needed since it was not designed for a moved IAT. Ultimately, you can run it without a problem.
#63
O2 bung will be installed tomorrow. I gave the car a couple of WOT runs today just to see, and there was no engine knock. Seems like we are moving in the right direction.
From now till Tuesday I'm just going to be commuting, and once we hit the dyno and see whats going on with A/F ratios........we'll figure this car out.
#65
ORIGINAL: Justin00Stang
Other opinions please?
#66
I've already given it full throttle up to 130mph to test, and there is no engine knock. I'm also running the 3.625" pulley so that helps reduce load, and risk of severe detonation anyway.
Its on the dyno on the 15th.........everyone just wait patiently and I will be able to tell you whats going on after that.
It could be an altitude thing (3000+ feet) reducing exhaust backpressure more then expected. It could be my car.....just being a bit different. Many things........but until I get it tuned with a/f ratios......we won't really know. If it makes the right power with the right timing and A/F....then there is no problem.
#67
We ended up installing a wideband o2 as well while doing our long tube install with use on our whipple. My inital input as well would to have said you should have aquired theFRPP procal tune for use on on your vehicle.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
01roush33
05-26-2006 09:32 PM
