Flywheels
Old May 21, 2008 | 03:08 PM
josephspann's Avatar
josephspann
Default Flywheels
Aluminum or steel? And what is the advantages and disadvantages of each compared to each other not to the stock flywheel?
Old May 21, 2008 | 03:09 PM
josephspann
Default RE: Flywheels
And might as well take your suggestions on which clutch to use too seeing as I will replace them together.
Old May 21, 2008 | 03:24 PM
sactown's Avatar
sactown
I am currently running a SpecsII+ with Aluminum flywheel and it is a piece of $hit, I am replacing it with a Mcleod RST Twin disc and the Mcleod Bearing kit and a new stock steel flywheel, Itossed out the orginal flywheel [:@]
Old May 21, 2008 | 03:54 PM
05Saleen#243's Avatar
05Saleen#243
I'm running MMR's stage II with Fidanza billet aluminum flywheel. Really smooth, but with the lighter flywheel the RPM's drop off faster between shifts so you have to give it a little more gas.
Old May 21, 2008 | 05:25 PM
moosestang's Avatar
moosestang
Do a google search for Steel vs. aluminum flywheel and you will find more info and opinions than you need. I'm not going to go into all the advantages and disadvantages for the two.
I chose a spec stage 2 with spec billet steel flywheel and couldn't be happier, so far. I'm still not sure if I should have went with the stage 3+ or not, but I would be wasting it's potential i'm sure.
It even cured a vibration I had at 3200rpms. I guess my stock flywheel and/or clutch was warped.
Old May 23, 2008 | 02:05 PM
jerjan's Avatar
jerjan
I'm using a spec stage II with aluminum flywheel. Love it! It revs much faster than the original steel flywheel. Kinda the same feeling and difference it made when I replaced the driveshaft with an aluminum one. Me likes it alot!
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
