05-09 GT Triple Pump Fuel Systems IN STOCK!!
Old 07-03-2008, 12:58 PM
Boostaddict
Former Sponsor
Boostaddict's Avatar
Default 05-09 GT Triple Pump Fuel Systems IN STOCK!!
We're proud to announce that we now have in stock and ready to ship the same day you order the Triple Pump Complete Fuel Systems for the 05-09 Mustang GT.
That's right. The long awaited components from the collaboration between Lethal Performance, Fore Precision Works and Zone 5 Performance are finally here and ready for purchase. Lethal Performance is the ONLY place to get these products at this time. So if you're looking to purchase the entire system or just the components just give us a call and we'll be glad to assist you.
This system has been in the making for quite sometime. It was developed as an answer to fuel system limitations placed on the S197's.
$1899.00 Complete.. From the tank to the rails.
http://www.lethalperformance.com/pag...el-system.html
This fuel system is by far the most advanced and efficient system available offering the customer exactly what they've been looking for. The ability to safely back up the power with a simple bolt on system that's made to perform. Just like our 03-04 Cobra fuel system which utilizes the Fore Precision Dual Pump hat we're extremely excited to now offer a similar version for the S197 crowd with the addition of a third pump. That's right!! A third pump option will now give you the ability to support over 1000rwhp. Accompanied with the Zone 5 Performance MDM you can control 1, 2 or 3 pumps efficiently. What's also great about the MDM is how simple it is to install. Rather than having to make new wiring harness's and such the MDM simply uses the output of one of the stock FPDM's and has 1-3 outlets to run to the pumps. It comes with all the necessary mounting hardware and connectors along with detailed installation instructions. We installed an MDM on our GT500 while it was on the dyno in less than 30 minutes.
Initial testing with this system showed us an amazingly low peak duty cycle of 72.5%. With the stock setup at the same HP level we were seeing duty cycles in the low 90% range. That's a solid 20% drop in duty cycle which means this system has a lot more in it.
This system is something that's never been done before on the S197 and our good friends over at Zone 5 Performance and Fore Precision Works put in lots of time and experience into developing the components to this system. So whether you're running 500, 600 or all the way up to 1000+rwhp this system has everything you need
The Lethal Performance Complete Fuel System Includes:
-Fore Precision Works Triple Pump Fuel Hat
-3 Ford GT Supercar Pumps
-Zone 5 Performance MDM Mega Driver Module
-Fore Precision Works High Flow Fuel Rails -Satin or Black
-Aeromotive 10 or 100 Micron Fuel Filter
-Fragola 3000 Series Pushlite Fuel Hose
-Fore Precision High Flow Y Block
-OEM Level Sender
-Fragola Fittings, Clamps, and all Hardware needed for installation
-Complete Installation Instructions
FORE PRECISION WORKS TRIPLE PUMP FUEL HAT
The ultimate solution for S197 fuel systems is finally here! Introducing the all new Fore Precision Works S197 Triple Pump Fuel Hat.
Up until now the best solution for GT's and GT500's was to run the stock or modified GT500 system. Another solution for the GT was drilling holes in the stock fuel assembly and adding an additional in-tank pump by strapping it to the assembly. Although these systems have held up and worked well for the last few years we definitely felt there was many improvements to be made. The other issue is that all Mustang GT systems only use a single Fuel Pump Driver Module. If you wanted to upgrade to a dual driver system the only way would be to purchase the entire GT500 system. Reason being is that the stock GT hat doesn't accept the connection for the dual drivers as well as the pigtails needed to make the dual driver harness's aren't available for purchase through ford by themselves.
Another major weakness of the stock fuel assembly is the size of the feed at the top of the assembly. No matter how good of a pump you put into the assembly they're trying to push fuel through the small straw sized opening. In addition to that the stock fuel lines, connection at the filter and connection at the fuel rail are all bottlenecks which keep the efficiency of the system very low.
Problem Solved!!
The Fore Precision Triple Pump Fuel hat is the solution. Just like the Fore Precision 03-04 Cobra hat the S197 hat is made from high quality billet aluminum and machined to perfection. Using high quality fittings and 30R10 submersible lines this system is a direct replacement for the stock assembly and still utilizes the stock level sender and venturi pump.
One of the main features of the Fore Precision Triple Pump hat is that it's the only system on the market which allows for 3 Ford GT Supercar pumps to be used in tank. You actually have the ability to run 1,2 or 3 pumps at a time so depending on your specific needs you can custom tailor your setup with this piece. In order to run the 3rd pump you'll need to use the Zone 5 Performance MDM Mega Driver. The Mega Driver is an all in 1 driver box similar to an FPDM but allows you to run anywhere from 1-3 pumps at the same time. The MDM Mega Drive provides the pumps with the proper amount of voltage to handle the power that the pumps draw.
Fore Precision Works Triple Pump Hat Features:
-High Quality CNC Machined Aluminum Assembly
-Direct replacement and bolts right in using an OEM gasket for a perfect seal as well as using the OEM fuel sending unit in the same stock location.
-Houses 3 Ford GT Supercar Fuel Pumps
-Triple -6an Outlets
-Pre-Wired for Dual FPDMs or Zone 5 Performance MDM
-Eliminates the PPRV and offers a direct in-tank hose routing to both fuel pumps for optimum fuel delivery.
-No welding or caulk used in assembly or manufacturing. Full billet components use o-rings, OEM seals, and gas blocked through conductors.
-All assemblies are pressure tested prior to shipping.
ZONE 5 PERFORMANCE MDM MEGA DRIVER MODULE
- DRIVES UP TO *THREE* FORD GT PUMPS TO MAXIMUM FUEL CAPACITY
- DESIGNED TO INTERFACE PERFECTLY WITH THE FORE PRECISION TRIPLE PUMP FUEL HAT!
- CAN SUPPLY IN EXCESS OF 35A OF CURRENT WITH LESS THAN 0.5V TOTAL INTERNAL VOLTAGE DROP (as a comparison, the stock FPDM will drop approximately 2.0V at ~ 20A of forward current)
- OPERATES AT TWICE THE OUTPUT FREQUENCY OF THE STOCK FPDM FOR SMOOTHER PUMP CURRENT CONTROL RESULTING IN POTENTIALLY LONGER PUMP LIFE AND BETTER FUEL PRESSURE REGULATION
- BUILT-IN WIRING UPGRADE AND HIGH CURRENT RELAY
- 8AWG INPUT WIRING FOR BATTERY CONNECTION
- 14AWG OUTPUT WIRING FOR EACH PUMP
- BEAUTIFULLY CNC MACHINED HOUSING/HEATSINK BY YOUR BILLET EXPERTS "FORE PRECISION WORKS"
Boostaddict is offline
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
DrunknRuckus
08-23-2015 10:05 AM
drumhedd2005
08-13-2015 09:59 AM
FD725
08-11-2015 03:43 AM
Quick Reply: 05-09 GT Triple Pump Fuel Systems IN STOCK!!
