tachometer
Old Jul 9, 2008 | 07:55 PM
  #31
VistaGT's Avatar
VistaGT
Default RE: tachometer
Regardless of what car it's for it's DEF. a shift light logo. The same one lights up in my buddy;s 03 cobra
Old Jul 9, 2008 | 08:12 PM
  #32
conrader's Avatar
conrader
any ideas on how to get it to work on a 2005 mustang gt?
Old Jul 9, 2008 | 08:47 PM
  #33
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: TimeForPain
the gt500 has 2 different shift lights, theres the amber arrow one, kinda like the one you guys pictured which basically tells when to shift for fuel economy and then theres the svt shift light... that one is basically like your normal racing shift point... adjustable to 6k or where ever you like shifting, the arrow for fuel isnt adjustable.
Its like you are reading it directly from the workshop manual.
http://iihs.net/fsm/?dir=343&viewfil...%20Cluster.pdf
Old Jul 9, 2008 | 08:53 PM
  #34
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: conrader
Contact your dealer and sweet talk him. [&:]
Or hack the Fords PCMs code and write the lines in yourself.
Download the PCMcode from a GT500 that has the light to your laptop.
Download the code from you stangs PCM to your laptop also.
Use the editing program you wrote specifically for cracking Fords PCM
code and marry the shift indicator portion of the GT500s code into your
GTs code without causing any bugs to appear.
Then upload the new code toYOUR GTs PCM and cross your fingers.
See if she will start then take her for a ride and admire your work.
Pretty simple, or is it?
Be sure and save an unadulterated copy of your 'as built' code in
casethe shift light modified code does not work.
Or buy a Raptor shift light and drill a 3/4" hole in the back of your
insturment cluster right below the 4 on the tach where the UP ARROW
is located. Then insert Raptor in from the rear and wire as directed.
Form meets function.
93rustanglx
Sep 20, 2006 10:36 AM
elmustang5.0
Jun 17, 2006 12:55 AM
fle5141181
Jun 7, 2006 12:59 PM
cletusboyer
Feb 10, 2006 12:41 AM
92FordGt
Oct 31, 2003 09:35 AM
