Code 0340 (Rebuild optional ?)
Old Nov 26, 2008 | 02:38 AM
TheLowsters's Avatar
TheLowsters
I have an 06, when my alternator started to go my car started surging when you gave it throttle while in 5th gear. Eventually I got the check engine, went to the dealership and they replaced it. So far on my 2006 GT with 28,000 miles, I'm on my 3rd Shaker 500 head unit, 2nd passenger front 02 sensor, and a 2nd Alternator. Is this normal for a Ford?
Old Nov 26, 2008 | 05:41 AM
Bmr4life's Avatar
Bmr4life
Crap, how did I miss that. My car has been surging as well sometimes.
Old Nov 26, 2008 | 09:14 PM
will's Avatar
will
Isn't p0340 a cam sensor\circuit code?
Old Nov 26, 2008 | 11:30 PM
Bmr4life's Avatar
Bmr4life
yup, but 90% of the time it means alternator.
Old Nov 27, 2008 | 02:29 AM
ILikeBond's Avatar
ILikeBond
+1 (to the whole P0340/344 error code deal).
Does the 200 amp alternator at Pa-Performance provide a stronger fix to this problem than the 130 amp, or would you only need the 200 if you're running heavy electronics, like a sub or something?
Old Nov 27, 2008 | 02:40 AM
Leos06gtLL's Avatar
Leos06gtLL
sorry you joined our club. do you have a shaker 1000 both my buddys and mine went out at 24-25k miles.and we both have the shaker I think they run a heavier duty alt (not sure though) and both had the P0340/344 error code
Old Nov 27, 2008 | 01:08 PM
will's Avatar
will
Nice to know thank you
Old Nov 27, 2008 | 03:45 PM
buster's Avatar
buster
Originally Posted by Hufenstang
what are the characteristics of a bad alternator in these cars? Just rough running or what?
When you are standing on the side of the road with a car that won't run. Seriously, your headlights will generally get dim because your motor is using the battery to power the ignition. As you probably know the battery does eventually run down. If your lights start getting dim, turn off all unnecessary items (ie a/c, stereo, heat etc.) and get to a garage ASAP or you will add a tow charge. Or it just won't start. My 01died suddenly when I was leaving work. I thought it was the alternator. I had it towed to the stealership and it turned out it was a dead 2 year old battery. A new battery cost me almost $250 factoring in the tow.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
Drastang
Sep 30, 2015 03:48 AM
