View Poll Results: Lowered cars vibrate?
Lowered and NEVER vibrated
60.00%
Lowered and DID vibrate
40.00%
Lowered and STILL vibrates
0%
Gave up and took it off
0%
Voters: 10. You may not vote on this poll
Spydershaft and Lowered
I have a coast ds, Steeda springs and lower control arm relocation brackets with steeda lca's and have no problems, could def. tell when I put the alum ds on. but I have side exhaust so that drowns out a hole lot of road noise.
Every car is different so go ahead and give it a try... Make sure you set the pinion angle I am sure the more HP the worse the efeects could be. Im at 400 hp with zex and 310 around town. good luck
I have a denny's 3 or 3.5 inch steel drive shaft and i'm lowered 1.5 inches all the way around. I had a vibration over 70 and some vibration on decel, but rotating the shaft and adjusting the pinion upward solved all my problems. Have had it up to 120ish and no vibrations.
