boost
Old Dec 27, 2008 | 11:22 AM
Metztang's Avatar
Metztang
Default boost
is more boost better than less boost?I see some cars with more boost than other but are making the same rwhp. So,can u run less boost and run more rwhp?and is less boost safer?
Old Dec 27, 2008 | 11:44 AM
xfactor95's Avatar
xfactor95
Less boost is "safer" only if it is tuned right. You can also have more rwhp with less boost if you have a larger displacement.
Old Dec 27, 2008 | 02:13 PM
forensicsteve's Avatar
forensicsteve
Are all the rwhp results from the same dyno? Dyno numbers may vary hugely between dynojets and mustangdynos and even similar model dynos. Two of us with turbos dynoed on the same dynojet...then we both switched to the same mustangdyno (different days) and both saw a 25% drop in numbers on baseline pulls. It's just a number, a tuning tool.
Old Dec 27, 2008 | 05:16 PM
AmericanSpeed's Avatar
AmericanSpeed
I wouldn't pay too much attention to the dyno numbers, like forensic said, there can be a lot of variation between dynos. Look at trap speeds from the 1/4 to make a better comparison.
Old Dec 27, 2008 | 05:28 PM
Stkjock's Avatar
Stkjock
Retired Mod
boost is a measure of restriction, a more efficient motor can make more power on less boost.
i.e. same blower/pulley on two cars, one a motor with heads/cams/ LTs/ o/r X-pipe will see less boost than similar motor without those mods but make more power. since the airflow is better there is less pressure seen
as mentioned above as well the dyno is a tool, the real test is at the track!
Old Dec 27, 2008 | 05:49 PM
mykim72's Avatar
mykim72
more boost is always better
Old Dec 27, 2008 | 05:59 PM
Stkjock's Avatar
Stkjock
Retired Mod
no its not, more power yes, boost not so much. If you can get the same power on less boost due to a freer flow of air and make the same power your engine is better off
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
