Should I be safe?
#22
Guys! seriously. Dude! a canned tune will not guarantee anything. Take it to your local Dyno shop and have them tune it for you. They will make sure that everything is correct if they know what they are doing. It's not worth ventilating your block with rod and piston pieces if you are running too lean. Custom combination tunes with various mods on supercharged motors is not something that tuners usually have special tunes for. In a nutshell a $50 tune could cost you your motor. Is it worth it?
#26
save yourself some money, and hard ache, and put a metal block under the gas pedal so you can only go to around 1/2 throttle. no reason spending 50 bucks if you don't have to. and it wouldn't be a bad idea to buy a wideband. only 300 for a little confidence.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
