BOOST A PUMP
Old Mar 26, 2009 | 01:41 AM
S197winstang's Avatar
S197winstang
Default BOOST A PUMP
What should the setting be on the boost a pump? The car has all the mods in the sig
Old Mar 26, 2009 | 03:03 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
What brenspeed recommends is turned to the full on (all the way up-50 right) and forget it!
Old Mar 26, 2009 | 03:05 AM
S197winstang
Perfect, Thanks. It was dyno tuned with it off.. We adjusted timing and a/f. Will the lack of the pump being active caue a loss of power? i hearing pingig on the freeway.. Yikes hope it did not hurt the engine. You think they should re-dyno? The car is a blast.
Old Mar 26, 2009 | 03:07 AM
mygt500's Avatar
mygt500
R U speaking of the BAP or lack of a fuel pump working? (say one of the GT500 duel pumps not working)
EDIT -I think you meant the BAP and if you hear pinging with the BAP on go back for a retune as something else is wrong (maybe just a tune issue-faulty wire/connection). If not with the BAP at full (50 confirmed by tacobill) you should have no issues throughout the powerband!
Old Mar 26, 2009 | 03:09 AM
S197winstang
The BAP was set to lean the whole time the tech forgot to set it.. Wondering if i set it to 50 will it improve performance. And for saftey should I asl the shop to redyno now that the bap is dialed in...
Old Mar 26, 2009 | 03:31 AM
mygt500's Avatar
mygt500
it should help if the lean condition was from the fuel pump or the current was not right at the time it was pinging.....remember that the stock fuel pumps max duty cycle when its reached its maxed out then and the BAP wont make any difference (it only makes the pump work better or decrease the chance of a hiccup when the cars load [current/amps] is at it greatest). So get it dyno'd again and see what the duty cycle on the pump is at WOT..... I am not really worried as your not near the max the pump can handle... I had the stock fuel pump for months before changing it at said power level in my sig and no issues.
Old Mar 26, 2009 | 03:40 AM
S197winstang
perfect, Thanks.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
mrappe
Sep 26, 2015 10:16 AM
