quick JBA LT question
Old May 6, 2009 | 10:16 PM
david01130's Avatar
david01130
Default quick JBA LT question
Im installing a set of JBA LTs in about 2 weeks. I still need 02 extensions and maybe new bolts. Where is the best place to get the o2 extensions? Do I need the new bolts? If so where can I get those? Are new exhaust manifold gaskets needed? Should I go ahead and throw poly motor mounts on there as well?
Old May 7, 2009 | 09:00 AM
MadMike1337's Avatar
MadMike1337
they should come with the bolts in the box with the headers. what year is your car? you may want to go to ford dealer and pick up some gaskets. i reused the gaskets mine is an 08 with 10k on it. i installed JBA shorties and have steering rub from a clearence issue with the headers and steering link. i just ordered the porthane mounts and now i have to fight with tight space. im not sure if the LT's will rub i have heard some have so you might wnat to look into it. decide be4 you put the headers on because there is a ton of room once the stock headers are off. also get some geared ratched flex wrenches. 1/2", 8mm and 15mm worked for me although i kind of wish i bought the whole metric set haha
Old May 7, 2009 | 12:52 PM
david01130's Avatar
david01130
ok thanks for the info. I bought the headers used so all it came with were the headers and mid pipe. Mine is an 06 with only 10k miles.
Old May 7, 2009 | 12:56 PM
MadMike1337
also get a can of penetrating oil to prep the bolts be4 you back them out. the stuff is like a hot knife through butter. made things for me 100x easier. you can try www.brenspeed.com for o2 extensions i think www.americanmuscle.com has them too. look around
Old May 7, 2009 | 01:07 PM
david01130's Avatar
david01130
what about some of these?
http://www.jegs.com/p/Ford+Racing/763598/10002/-1
and these? (top of page)
http://www.bmrfabrication.com/2005MustangMISC.htm
and these?
http://www.americanmuscle.com/bbk-o2...harnesses.html
Old May 19, 2009 | 09:50 PM
david01130's Avatar
david01130
any other comments on this? Im going to try and purchase what I need today or tomorrow. I need O2 extensions but are the bolts and motor mounts necessary? If so where is a good place to get them and what kind/price?
Old May 20, 2009 | 10:54 PM
MadMike1337
i just installed the prothane mounts i was talking about. i would suggest getting them. the car feels tighter up front and your shifts feel 90% better. i dont feel any additional vibrations and all that from the mounts being stiffer. if you do get them you'll be suprised at how crappy the stock once are. they are more or less like jello haha
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
