Need advice on purchase
Old Jul 21, 2009 | 02:57 PM
genericusername's Avatar
genericusername
Originally Posted by JCON
I would generally tend to stay away from damaged cars, esp if an airbag went off. My last Passat was a W8 and had 38000 miles on it. checked the report after I bought it and it had the engine replaced, thought this was great because the known cam adjuster issue ($10k to fix) should be fixed by the revised part in the new engine. Found out from mechanics the revised part is no different and I should expect the same issue to happen in the next year or so. After 2 months of owning it the light came on and threw that code.... followed VW regs and did oil change and light turned off. Moral of the story, stay away from problem cars and cars with a lot of work done to them (unless its a modded car for racing then its probably ok as long as its not a DD). That W8, although functioning fine when I traded it will probably break down in the next year or two with more damage than the car is worth. Mustangs are great and reliable but I would avoid cars with extensive work done to them. You don't know exactly what damage was done to the car in the front end or underneath.
Whats you're zip? i'll see if I can find something reasonable. What options do you want?
30401 is the zip
would like between an 05-08, GT, would like to stay under 35-40k miles if possible. Am flexible on auto or manual. Will be paying cash...so I dont want to go any higher than 16,000 if possible. My friend has an 08 GT w 25k miles on it he would LOVE for me to take over payments on, only drawback is theres still like 19,800 owed on it. Yikes.
Old Jul 21, 2009 | 05:24 PM
will's Avatar
will
Hell I got my 05 GT all the goodies 9679 miles on the odo for 18K
Old Jul 21, 2009 | 06:23 PM
JCON's Avatar
JCON
http://www.vehix.com/inventory/Vehic...pPrice%25257C0
See if this guy would go for 16k in cash. Listing expired so he may not of sold it yet. He is looking for a payoff, but he may not have an option.
I looked on vehix, autotrader, kbb.com, and did a search for local dealerships. unfortunately I couldn't find much in the way of an 05+ GT for $16000. Most of what I am seeing is 18-21K. Most dealers mark up around 3k on used cars. ( My 05 was marked up almost 5k)
Old Jul 27, 2009 | 07:21 PM
genericusername
just a quick update...
i ended up buying an 06 GT perfermance white today. It has 35000 miles on it. Actually got it from a member on here.
Has the MyColor dash option. MAC axle-back, Clear corners/parking lights, Rear black out panel, 30% tinted windows, Shorty antenna (14"), FRPP lowering springs, Tokico Shocks/struts.
Old Jul 27, 2009 | 08:11 PM
Nuke's Avatar
Nuke
A loaded '06 GT should be had from a dealer for no more than $17k-18K, tops. I just bought a mint '06 V6 pony package with 9K miles for $13.5k. Search around. If you know what you're doing you can get an '09 or '10 for at least $2-3k below invoice, BEFORE rebates.
Old Jul 28, 2009 | 12:49 PM
bynumj's Avatar
bynumj
"just a quick update...
i ended up buying an 06 GT perfermance white today. It has 35000 miles on it. Actually got it from a member on here."
What did you Pay?
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
GLOCKer
Sep 28, 2015 07:36 AM
