Just Curious....
Sentimental reasons...
None of our business, but if it has to do with someone else either owning the car before you, or having something to do with the money you used for the purchase, I guess you have to ask yourself if they would be happy knowing you were miserable?
I understand sentimentality a little. But you have to make yourself happy.
Best of luck, however you choose to handle it. Sounds like others have done the swap. I thought I saw a writeup on here already. Maybe search around.
quick list of parts here
PCM
Transmission
Flywheel
Clutch
Brake pedal set
Slave cylinder and all associated lines
Brake master cylinder reservoir
Bell housing bolts
Flywheel bolts
Brake pedal/clutch pedal set and switches
Shifter
Shifter rubber boot.
Shifter leather boot for console
Console trim piece
PCM
Transmission
Flywheel
Clutch
Brake pedal set
Bell housing bolts
Flywheel bolts
Shifter
Console trim piece
yes, please. Can you also tell me how much it's gonna cost you? the price of the tranny, and how long it's gonna/should take? thank you in advance.
