sct jlt issue
Just purchased sct tuner and jlt intake. I decided to use basic cantun until i get my headers installed. im running the unit on 87 octane ok heres the issue when drive and i come to a stop the car now idles down to 250rpm then pops back up to 750 regular idle speed when instock configuration and stock air box car never did this any ideas of what wrong ?
Who's tunes do you have? Are they the canned SCT tunes or a custom tune? I'd contact the tuner but it could simply be that you need to crank a few miles on the car so the PCM has some data for the adaptive learning.
im currently just running the canned tunes from sct for jlt intake. I yestarday my car actully turned off. when you start her up everything is good revs up to 2k then settles down to around 100 then slowly drops when she gets warm. apon driving when you get to a stop light the car drops to around 250 rpm then shutters as if it wants to turn of then bounces back up to 750 rpm
There's 3 things I would do first.....pick up some MAF cleaner and Throttle Body cleaner at your local auto parts store and clean both of them off good (for the throttle body I took mine off so I could clean the butterflies good inside and out). Then after that, unhook your battery for 30 minutes and then per the owner's manual, do through the re-learn process so the car can re-learn the idle & fuel trims.
03blackwidow
Sep 20, 2015 02:36 PM
