Brake upgrade on a budget?
If you're going for appearance, performance and budget then I would recommend stainless steel brake lines, completely flush out the current brake fluid and replace with DOT-4, get those calipers powder coated being he's giving you a good deal. It's not really needed to get crazy with pads. In my experience there really is no "good" inexpensive slotted or drilled rotor that wont crack so my recommendation would be a premium stock replacement rotor like Centric or Raybestos or even O.E.M. and a Centric 105 series set of brake pads.
I dunno, maybe make a new thread. I've been trying to find that question out myself for some time and I keep hearing different answers on whether the clutch line can/can't be bled, but nobody will say how to do it without pulling the trans.
Also nix on the DOT 5 fluid, I believe.
Cheers.
Same calipers = same pads = same contact surface area/pressure on the rotor = same stopping power? I would assume that this is the reason that you don't see many people using this.
The reasoning is to move the caliper outward toward a greater radius, thus having more stopping power. Probably has a minimal effect but they do look cool and cost a heck of a lot less than a big brake kit.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
