I got a problem with my baby
allright , let me explain my problem
whenever i start my car the car turns on and then the rpms drop and it dies , in order that it doesnt die i have to press the gas and it shoots out a **** load of gas and blue smoke , then the rpms kinda go from low to high for a while and it has alot of hesitation when i drive
i think that my fuel pump is messed up , my car had been sitting for 8 monthes while i was in afghanistan so i think it migth have gone bad , its also telling me that my o2 sensors are going bad , but that could be because of the fuel being shot out of my exhaust ,
anybody got any suggestions ?
Have you had a chance to run the tank down and refill with fresh fuel? I'd check that out first, then determine if it's a mechanical problem or something simple like a TB cleaning.
WHAT is telling you that your O2 sensors are going bad???
I don't know but seems to be a problem in the combustion process. Especially if fuel is coming out the exhaust pipes. Possibly not enough spark to ignite the combustion but just enough to stutter it along, and the remainder is being shot through the exhaust valves... but I don't even know if that's possible. Check your obvious indicators. Throttle body, intake, etc. (Airleak, however small or slim will give you hesitation/stalling)
Not sure any of this has anything to do with your 02 sensors though.
oh yeah i have gone through several tanks and it just keeps getting worst , my buddy had a hand held device that told me some of my o2 sensors are stuck on rich and some stuck on lean , i dont know if it is that or what
NUKE is right start with a fresh tank of gas, after 8 months it's probably down 20 octane points and is varnished. What about battery? Was it left to go dead? Also the excess gas isn't going to through codes for your O2 sensors, they're oxygen sensors not fuel sensors.
stangin1996gt
09-21-2015 11:01 AM
09-16-2015 03:07 PM
