10% crank pulley on m90
going from a 2.875 pulley to a 2.49 pulley gives you 13.3%, so there's your comparison, the 12% overdrive won't quite get you as much boost as the supercharger pulley swap would have.
On a centrifugal blower, they have an upward curve at higher RPMs, they get more efficient as they spin faster. And that's why I said that it might give 2-4LBS on a centrifugal supercharger.
That's one way, ha!
You can't just say each PSI = xhp. The M90 becomes extremely inefficient above low boost levels, so your return in HP for each psi becomes less and less.
I can't recall a M90'ed car being above 450-470 to the tire with full boltons.
OP, don't get your hopes up with the above #'s. For reference my buddy is running 7psi on his M90, JLT intake, with O/R exhaust and a mild comp cam. He put down 405 to the tire.
